FAST 92/LS2 TB install
i am finishing up my install of a FAST 92mm intake with a new LS2 TB and i have some questions. First off the lines that run coolant to the stock TB no longer have a place to contect on the ls2 TB. What do i need to do here? Do the TB by-pass mod? Also the vent hose that runs from the passenger side valve cover to the stock TB no longer has a place to go. Can i just block this off, put a catch can there, etc? Thanks for any help.
I'm running an LS2 TB. You will need to bypass the coolant. As for the breather line, I fastened a filter for an air compressor on there. I believe you could also plumb it into the air intake tract.
