04Z06 trans leak
04Z06 trans leak
Can anyone recommend a shop in Knoxville, TN to take my C5 Z06 to, for a fluid leak from my transmission.
Had output shaft seals replaced as a stipulation of the used car purchase.
I have a Monster stage 2 clutch kit NIB waiting to be installed.
Maybe I could get both done at the same time.
Thanks for your help,
Dave
Dave
With the transmission and axles out, that would be the best time to replace any seal(s) that might be leaking.
I used to pull the trans all the time when I had my F-body because it wasn't to bad once you got used to it. A clutch replacement on a Vette is alot more work, especially doing it on the ground with jackstands.
When clutch time comes near for my 04Z, I will decide if I will pay someone or do it myself.
