Hinson Engine & Trans Mount - Flash Sale! Limited Availability
HINSON C5/C6 Urethane Engine & Transmission Mount Weekend Only Flash Sale
Use these codes and save for this Weekend ONLY. There are a limited number of coupons available, so get yours before the promotion is Sold Out.
C5/C5 Engine or Trans Mount Coupon - Save20
C5/C6 Engine & Trans Mount Combo Coupon - Save40
MADE IN THE USA!!!
These urethane engine mounts are designed for a great balance between engine control and vibrations. They have been tuned for both street and track applications. Replace your stock rubber mounts for improved throttle response and reduced engine movement.
Features
* Designed for street and race cars
* Direct replacement for stock rubber mount
* Uses factory metric nuts (not included)
* Stainless Steel construction for rust free operation
* Interlocking design for fail safe operation
* Uses factory heat shield (factory heat shield is required)
* Fast installation
Applications
* 1997-2013 Corvette C5/C6/Z06
Urethane Engine Mounts Standard Height C5/C6 Click for Pricing
OEM Standard Height
Urethane Engine Mounts (Shorter Version) C5/C6 Click for Pricing
.360" Shorter
Also Available in Engine & Transmission Combo Packs
Urethane Engine & Transmission Mount C5 Combo Pack Click for Pricing
Urethane Engine & Transmission Mount C6 Combo Pack Click for Pricing
*Want to become a dealer for these items??? Email chris@hinsonmotorsports.com
Why Are They So Much Better?
As you can see in the below cut away image, the engine rides on the durable urethane. This is how we control engine movement while not passing every vibration in to the passenger compartment. The inside of the mount is interlocked. Even if you found a way to damage the mount, the stainless interlocking design will keep it all together. The design is built with stainless steel, so they will not rust. They accept your factory nuts. This means there will be no emergency hardware store trips.
