Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Stainless Lingenfelter 2.60" two piece 10 bolt LS9 supercharger pulleys
Old 02-22-2017, 01:40 AM
ProServ's Avatar
Default Stainless Lingenfelter 2.60" two piece 10 bolt LS9 supercharger pulleys
Lingenfelter Performance Engineering (LPE) made a batch of stainless steel 2.60" two piece 10 bolt LS9 supercharger pulleys and we bought up the remaining inventory. Only a few remain.
On sale for $129.95 each
Listed on eBay here.
Purchase on eBay or PM us to purchase directly.
Stainless steel Lingenfelter 2.60" two piece 10 bolt LS9 supercharger pulley
For ZR1 Corvette & GMPP LS9 crate engine
PN L220146109SS
  • Lingenfelter Performance Engineering 2.60" diameter, 11 rib two piece 10 bolt LS9 supercharger pulley in stainless steel
  • Two piece design allows easy changes to other pulley diameters. LPE also offers a 2.35" diameter pulley so you can easily further increase boost for at the track with a simple pulley change (belts and idlers may also need to be changed depending on the application - click here for pulley and belt length chart for the LS9 engines)
  • Requires LPE 10 bolt hub kit (not included)
Per LPE:
Testing at Lingenfelter has shown 680 BHP and 660 lbs ft of torque with this pulley. The pulley will overdrive the supercharger 19% to raise boost on a stock engine by 3-4 psi. The stock serpentine belt is retained but the installation will require ECM programming to adjust ECM overboost limits [NOTE - IDLER PULLEY DIAMETER CHANGE REQUIRED - NOT INCLUDED].
Same diameter pulley as is included in this kit described above (except the pulley for sale here is in stainless steel and is a two piece design)
19% over-drive compared to the stock pulley
If all the other pulleys and pulley locations on the engine are stock this pulley requires you to change the stock 90mm idler to a 100mm idler (not included)
Stainless steel pulley for the ultimate in durability and appearance
Limited quantities available of the stainless pulleys
Includes: Pulley only
Fits:
  • 2009-2013 ZR1 Corvette
  • GMPP LS9 crate engine
  • Also fits LPE LS9 SC front cover (10 bolt hub kit already installed on the LPE LS9 front cover)
Quick Reply: Stainless Lingenfelter 2.60" two piece 10 bolt LS9 supercharger pulleys
