My review, Roadmaster Model REJ2000 Electric Sissor Jack
Picked one up to use mainly on the fronts of our lowered cars.
My portable mini jack is 21 lbs, I carry it on trips incase of a flat so I can jack up the tire @ install tire plugs or to swap out my wheels at the racetrack: D.
Had seen these before ..............after I saw a couple of posts on the CF,I bought one. Works like a champ after a mod
Walmart...........$54
http://www.roadmasterusa.com/rm_12v.html
As for the star wrench, weight/size is nothing and it's as fast too
Weight is 11lbs in the carrying case.
Height new is 4 1/4" high from top to bottom.
Takes me 40 seconds to raise the rear with either to swap tires.
35 seconds to let down the electric jack, 5 seconds with the hydraulic.
Front takes 40 seconds to raise with electric and twice as long with hydraulic due to the close quarters AND I need to drive on 2 x 12s to raise it enough to get the hydraulic jack under the front
This is as new............to tall to fit under my 97'
After my mod...........3 5/8" top to bottom, fits now
Fit under our slightly lowered 00's as new
As modified to fit under the front of my 97', don't even need to steer the tires to one side..........fits between the tire & front air damn
Worked great at the track Sunday
