Stock 02' Z06 fuel system limits?
When running stock injectors what can the stock 02' z06 fuel system support? I plan on upgrading to 30lbsvo injectors, but when will the stock pumps not supply enough fuel?
I suppose I could use the Racetronix hotwire and pump setup or just run my own line to the pump, but is all of this needed when running a heads/cam 450whp car? If I decide to run nitrous (100-150shot) later will I need more pump then?
I think you will be good at around 470 or under on motor.
Your setup will be good with a 100 to a 150 wet shot without the use of an additional fuel source. I would, HIGHLY recommend something anyways.
I have 42's right now, on a stock pump. I do have a racetronix piece, I hope to have in this weekend.
