vette one tire fire?? wtf?
was at the track last night on BFG DR's, started to do a 2nd gear burnout. Started off both tires, then after a few seconds, the right tire stopped but the left kept spinning. It only spun for a second but I was freaked out alittle bit. it ran down the track fine and drove home fine. Think this is something I should be worried about??
1 Post
I would contact (DTE) dynotech engineering here on the forum. They carry new clutch packs for rears and offer some greats products from what I have and researched. I am about to order there strut brace.
traction control was turned off. I was told by come older vette guys that vettes cant handle burning out in 2rd. Since it was the first time and only time its done that, i should be ok. At worst, I burn a little rear clutch but drove it all day today, launched a few times and it seamed fine.
rear clutches slipping, CHANGE YOUR DIFF. FLUID, happened to me..... and no **** the fix is LUCAS OIL!!!!!! I put 1qt synthetic lucas and 1qt mobil 1 75/90 and no more diff. slip problems, amazingly its like new again... do a bunch of slow figure 8's in a parking lot after you change fluid...
