got a broken vacuum line under battery, cant find where it goes to!
I know someone that has an 02 vette with the MIL on. It set the code for the AIR system. I removed his battery & found 1 vacuum line broken & cant find the other end to it. Theres 2 lines that go right under the battery tray, the 1 thats good goes into the wire loom behind the engine & is a lil bigger. Does anyone have a pic of these lines & how they route? I pulled the bottom panel off & looked up under the r. fender. All the lines coming off the vacuum tee at the vacuum reservoir are all intact, but that is where the broken one connects & runs up by the battery tray.
The vacuum source is on the back of the intake just below the MAP sensor.
From there it runs to the vacuum tank below the battery tray.
There are two vacuum lines from the tank, one goes into the dash to supply the HVAC, the other goes to the front left of the car to the AIR pump.
