Quick vid of some passes this past weekend.
Had some brake hardware issues the last attempt out. Long story short, brake caliper bracket came out on the way to the track, locked up front wheel, needed replacement bolt, finally got it. Fixed some other issues like a leaky S60 with a lubelocker gasket (awesome!), grant steering wheel issues fixed (clock spring yanked), and needed an alignment due to damaged alignment hardware from the wheel lockup. Went up 1 lb. psi to 16, car isn't bogging as bad out of the hole, probably need another lb. Will test later, but car is snatching pretty good I think. Other runs were a wash, guy running the burnout box seemed new and my burnouts weren't great because of positioning.
First pass matched PB, 11.9 @ 117 on a 1.62 60'. Colorado air sucks! Here's the vid! Helpful comments welcome.
