My new setup... check it out!!! Anyone run a 382?
Old 03-19-2006, 11:41 AM
MY LS WON's Avatar
Default My new setup... check it out!!! Anyone run a 382?
Anyone else have a 382? what kind of power should I expect when it's all put together... what do ya think it will run in the 1/4?
Transmission
*Rebuilt T-56
*McLeod Stage 5 Clutch
*Adj Master Cyl
*Ported Slave Cyl
*B&M Ripper Shifter
Exhaust
*Pacesetter 1 7/8 ceramic coated headers
*Turndowns
Internals
*4340 Eagle 4.000 Steel Crankshaft
*4340 Eagle H-Beam Rods (6.125)
*Lunati Forged Pistons (3.905 bore, 10.9:1 Compression)
*Total Seal File Fit Rings
*Federal Mogul Race Bearings
*Double Roller Timing Chain
*Ported LS6 Oil Pump
*ARP bolts
Heads
*Ported LS6 Cylinder Heads # 243 (The intake bowl throats have been bored to 1.800, 64cc chambers, 215cc intake ports, 80cc exhaust ports)
*ARP bolts
Valvetrain
*LM Performance G5x3 Custom Cam 112 LSA, 232/242 Duration, 600/610 lift
*Harland Sharp 1.8 Rockers
*Patriot Dual Valve Springs
*Hardened Pushrods
*2.000 intake/1.55 exhaust valves
Intake
*Edelbrock Victor JR manifold
*Custom made elbow to TB
*FAST 90 mm throttlebody
*90mm MAF
Fuel System
*15 Gallon Fuel Cell
*AN Lines
*42lb Injectors
*Seprate Tank/Pump for N2O in place of battery
N2O
*TNT F1 System
*250 Jets
*(2) 10 lb bottles in back seat
*(2) Bottle Heaters/Jackets
*MSD Digital Window Switch
*ZEX plate for Victor JR
*ZEX Purge out nostral
Wheels/Tires
*Centerline Convo Pro's (15x6/15x10)
*M/T Sportsman 26x7.5x15, M/T ET Street 28x12.5x15
Rear End
*Mosier 12 Bolt, 4.56 gears, 33 spline axles, spool
*Narrowed rear end 3" on each side
Suspention
*Chromemolly LCA's/Torgue Arm/ADJ Panhard Rod
*Eibach Sportline Springs
*Air Bags in Rear springs
*AFCO Adj Shocks in rear
*Tubular A-Arms
Chassis
*8 Point Rollcage
*BMR Tubular subframe connectors
*Tubular K-Member
Other
*High Back Aluminum Seats
*15lb AMS Bulldog Flywheel
*Meizere Electric Water Pump
*Carbon Fiber Driveshaft
Old 03-19-2006, 05:31 PM
Bryan @ Speed Inc.'s Avatar
250 jets and a 4.56 gear??????? i don't know if it'll make it through the traps w/ out hitting the rev limitter.
depending on raceweight and you driving skills... it should be good for 10's on motor. i'd like to know how it works on the gas with all that gear.
Old 03-19-2006, 06:01 PM
ATVracr's Avatar
Pretty sure its a 383 but it sounds badass anyways
Old 03-19-2006, 06:42 PM
CHRISPY's Avatar
I had a 385 stroker running dual carsound cats and 3615 pound raceweight. Ran 11.0s@126-127mph on a 1.65 sixty all motor. Simliar cam specs but I had PP LS6 style heads.
Old 05-17-2006, 08:48 AM
SlickVert's Avatar
Sound like a awesome set-up.
How about and update?
Bob
Old 05-17-2006, 11:56 AM
Retired Street Racer
Matt D's Avatar
Pacesetter makes 1 7/8 Longtubes?
