LS1 water pump heater core hose block offs
Ok I cant find these anywhere. Where do you get the two small block off for the radiator hoses that got to your heater core. Thanks guys
I couldnt find a good block off either. I ended up making 2 plugs out of alum. and then using a 3" or so heater hose. not a single leak yet!! I have seen people use bolts aswell. the look of the alum. plug looks better then a bolt, and also makes the hose look not so bad.
if you know someone that works in a machine shop they could make a set fast. took me 20 min. on a chucker while eating my lunch. pm me if you want to see what it looks like.
built408 do you happen to have a pic of what that looks like? I was trying to do a search on the orielly's site and cant find it. If anyone has a pic that would be great. I think I may need something like this
ok. I get the idea. I just didn't know I could cap off the lines like that. I was worried the car could overheat, I thought maybe there had to be a loop there to prevent that.
I pulled the barbs out of the pump, and welded them shut. Not for the average do it yourselfer, but just wanted to let people know to keep an eye on those rubber caps.
I had some trouble with those plugs. They failed and started leaking, they weren't reinforced like a radiator hose is.
