Who's Motor/Mid plate?
Im running a Comp Engineering front plate, and mid plate. Both will need extensive work with the mid plate needing the most. Front plate comes un-trimmed so you will need cut, and fit it to the frame rails yourself.
Madman makes a nice plate setup that is as bolt in as can be for a front plate setup, cut to proper size to fit in the frame rails etc. I dont think anyone is putting out a mid plate that is simple to install - if youre planning to go frame rail to frame rail, all of them need a fair amount of work to clear headers, firewall, etc. Ive seen some people are using a mounting hoop of tubing that the plate bolts to and hangs down... do a search for midplate pics.
LS1Tech Sponsor
Thanks
