Meziere Race Water Pump Inlet Hose?
All those running a Meziere Race Water Pump, what did you use for the inlet hose with the stock radiator?
Bob
Bob
My top hose was the stock factory hose, and the bottom one I ended up going to Autozone and just finding one that fit. It took a couple tries but I found one that finally made the turn and after cutting the end down has worked out well. I'll look when I get home and see if there is a part number anywhere on it...
Bob
it was either a carquest or gates number prolly same thing #21191 its off a early 80's buick riveria just have to cut a bend outa it,its a perfect 90 from the rad to the water pump if u cut it right and looks mint ill try n snap a pic of it lata,to come up with it i just bent up a clothes hanger and brought to the store
