Drag Racing Tech
what transmission mount for th350?
Old 08-28-2009, 08:17 AM
tektrans's Avatar
Default what transmission mount for th350?
re-use stock one or is there another for the th350?
Old 08-28-2009, 08:39 AM
5.3LJimmy's Avatar
I'm using the same prothane mount with the 1/8" spacer that I had on my T56, which is a stock replacement. This has worked fine for me so I'm sure the stock one would work fine.
Old 08-28-2009, 12:43 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I'm running the Energy Suspension mount
Old 08-30-2009, 10:37 AM
b.d.d.'s Avatar
Regardless of application, the OE GM 350 mount has been the same since the early 70's. Nothing special required.
Old 08-30-2009, 07:05 PM
tektrans's Avatar
ok cool thanks guys!
Old 09-02-2009, 08:53 AM
Camaro396's Avatar
As others, I just used a standard Energy Suspension poly mount.
Old 09-02-2009, 10:18 AM
tee-boy's Avatar
Default mounts
you can get one from part store. Give them a vehicle that came w/ 350 (older camaro would be a good start).
For those looking for a 400 mount.. Early 90's Chevy 1 ton trucks came w/ 400 trans.
