Drag Racing Tech
Rear wheels?
Old 09-29-2009, 10:31 PM
zssman's Avatar
Default Rear wheels?
What wheel backspace would I need for a 3rd gen 9" under my 98. Its supposed to b 1 1/2 narrower on each side.
Old 09-30-2009, 07:08 AM
dschmittie1's Avatar
Well if it is 15 inches shorter per side then you would want a 15x10 on a 6.0 back space. The best thing I can say to do is measure to be sure. Measure a stock 5th gen rear from flange to flange. then measure your rear from flange to flange. Divide the difference by 2 then subtact that from the normal 7.5" BS with a factory rear.
Old 09-30-2009, 11:57 AM
MelScrilla's Avatar
4th gens need 7.5 in bs for a 15x10 so then you would need 6in bs if you were using that rear.
