Drag Racing Tech
Switch suggestions
Old 10-14-2009, 07:37 PM
98Camarod's Avatar
Default Switch suggestions
I've got a transbrake, 2 step and I'm probably going to have a line lock. What is everyone using for these as far as switch plates go and/or switch locations. Is it possible to have the 2 step and transbrake wired together?
Old 10-15-2009, 03:28 AM
96LT1355Z28's Avatar
I have my 2 step and line lock on the same momentary switch mounted to the shifter. The 2 step has a toggle in line between the box and momentary switch. This way I can have the toggle off and use the line lock for burnouts, then turn the toggle on for line lock and 2 step at the starting line. I would guess you could do something similar with your T brake.
Old 10-16-2009, 10:45 AM
98Camarod's Avatar
Ah that's a good idea. I didn't think about the toggle switch in line with it.
