Drag Racing Tech
Critique my launch
Old 10-27-2009, 10:18 PM
transam69230's Avatar
Default Critique my launch
I think the car has more in it, and if you listen carfully the car like picks up after it comes out. The 60ft time on this pass was a 1.47. I full suspension except rear shocks, running a 28inch MT drag radial, skinnie up front, and my mods are in my sig. This is leaving off of a 150shot out of the hole.
http://www.youtube.com/watch?v=4LWZZ...layer_embedded
Old 10-27-2009, 10:26 PM
Nimitz87's Avatar
hard to tell from that far away and angle. it sounds almost as if the nitrous is hitting later?
do you have it on a WOT switch and window switch?
Chad
Old 10-27-2009, 11:05 PM
Yea its not the greatest video I know. Yea the nitrous is on a WOT and and window switch(FJO mini). It comes on at 3000 Rpm and off at 6400rpm. The stall is a 3600 stall so I don't think there should be a reason for it to do what it is doing.
Old 10-27-2009, 11:52 PM
riceburnerZ28's Avatar
What rpm were you launching at? It seems to be a little slow out hole Imho.
Old 10-28-2009, 07:16 AM
I don't really remember but I am going to guess right around 2200-2400 rpms. That was the second run of the day, and I was launching it at whatever the tires would hold without rolling through the beams.
Old 11-19-2009, 02:45 PM
2002camaroSS's Avatar
smash the fjo and hit it with a big shot sally
Old 11-19-2009, 08:11 PM
billybadd's Avatar
Set your window switch for 1k rpms. That will wake that bitch up.
Get your self a wolfe rear sway bar too. more gear wouldnt hurt either.
Old 11-20-2009, 02:51 AM
He has a rear sway bar it just needs to be welded in. And the reason he runs that gear is because we used to run 3:73's in it and it was running out of gear before the end of the 1/4.
Old 11-20-2009, 06:39 AM
rpmauto's Avatar
it does look like it comes out a little soft on the vid. In person it looked good. Cant argue with times like that. It was nice to meet you guys at that event.
Old 11-20-2009, 11:26 AM
brandoz28's Avatar
its probably just taking that long to get to 3k to make the nitrous activate. set it to 2500 and see what happens
Old 11-20-2009, 12:00 PM
Dont want to set the window switch too low, and have a nitrous backfire!
Old 11-20-2009, 12:56 PM
Bitemark46's Avatar
whats the front struts set on (assuming they are adjustable)? I didn't see much lift..even after the spray kicked in. But even on the initial hit just on motor alone it should have lifted more than it did.
-Mark
Old 11-20-2009, 01:27 PM
Yea the fronts are double adjustable strange shocks. I was having issues with the driverside front not working properly(really stiff). It was sent to strange and gone through 2 months after I got the shocks. Besides that both of the front shocks are set to 0 compression and 0 rebound ( so most rebound and least compression). Maybe I have the dials the wrong way, but I have them turned all the way to minus side for both compression and rebound.
The car was aligned at a dealership, and I think they may have over tighten the lower A-arm and that maybe is the cause to why the driver side shock is much stiffer than the passenger side.
Old 11-21-2009, 06:32 AM
Navy David SS's Avatar
You are NOT launching hard enough. 3600 Stall??? I guess my question would be:
It looks like your built tranny should take the launch..
1) do you have a transbrake?
2) 2 step?
"In the day" when I was on nitrous, my stall was 5400, launch on 150 shot (some times 200) off the transbrake with the 2 step set at 5200. Got many 1.30 on 10.5 M/T - my engine was a completely stock bottom end.
Bottom line (IMO) is your RPM launch - 3600 is not going to cut it.
David
Old 11-21-2009, 07:33 AM
Okay so what do i need to do? I only have a stage 4 from FLT and they said that its on the limit right now of spraying 150 out of the hole. Yes the stall speed is 3600vig, I do not have a T-brake in the car, and I do not have a two step either. I thought the 2 step thing was more for the 6sp guys.
On a side note I really wish you (Navy David SS) would have made it to pinks allout in Cedar Falls, Iowa. Myself and a bunch of buddies were really looking foward to seeing your car! Its too bad you couldn't have made it, it was a really good time!
Old 11-21-2009, 08:44 AM
Old Geezer's Avatar
What are your datalogs telling you?
Look at what the engine is really doing, would be a way to sort things out.
Tps really at WFO, or is the driver's foot being pulled off WOT?? Lots of "stuff" to look at, B4 making a bunch of changes...
IMO, David is on w/ his suggestion on a converter.
REMEMBER! 1 change at a time, with notes, vids, etc, for reference.
Old 11-22-2009, 06:44 AM
Wish I would have the car finished also. Next year. Good things come to those who wait
Me personally, I would look at putting a transbrake and 2-step on you car. Re-flash the converter to 5000, and let it rip. Use the transbrake to activate the nitrous. Works great.
David
Old 11-22-2009, 04:27 PM
David
Did you have any problems blowing threw the converter on the nitrous?
Old 11-22-2009, 04:42 PM
01FbTaWs6's Avatar
and you shouldnt have ran out of gear with a 3.73 trapping 125... especially on a 28 inch tire. How much slip does your converter have?? you must have a TON of slip to be running out of gear at 125 mph on a 3.73 with a 28 tall rear tire...
Old 11-23-2009, 01:02 AM
He used to run 17's and they werent as tall as the tires he ran now.
