Drag Racing Tech
What style harness to use with roll bar/cage setup
Old 03-16-2010, 09:52 AM
03 BUSA's Avatar
Default What style harness to use with roll bar/cage setup
For right now plan on using factory seats with an 8 point setup. I am purchasing the Burkhardt crotch strap setup. Looking at an Impact 5 point bolt in?? Not sure if it is preffered to wrap the crotch strap and shoulder straps but bolt the side belts to the rear seat bolts?? Let me know how you guys installed them. Thanks.
Old 03-16-2010, 01:01 PM
94Z28rag's Avatar
I had brackets welded on for my Impact 6-pt setup.
Old 03-16-2010, 01:06 PM
1lejohn's Avatar
I wraped the shoulder harness and crotch starp, bolted the lap belt onto the stock lap belt bolts. I kept the stock belts also for normal driving. The only problem with the stock seats are that the belts slip off the seat back
Old 03-16-2010, 09:06 PM
03 BUSA's Avatar
I would like to wrap around the bar for the shoulders and the crotch but be able to bolt the lap belts in. Is there a kit that would accomodate this? Can't seem to find anything on summit's site.
Old 03-16-2010, 09:23 PM
DiabloFormula's Avatar
I'm going with a set of RCI wrap arounds for the shoulder and crotch once I get my 6 point in, I think I've heard that the trans am seat will accomadate the shoulder belts better the Camaro seat would and Wolfe sells a bolt in bar that can be used for a wrap around crotch setup.
Old 03-17-2010, 08:09 AM
mad_steve's Avatar
Give me a call. I can get you the 5-point harness from Stroud, the Wolfe crotch strap bar, and anything else you may need. Our number is 225-673-3533.
Old 03-17-2010, 12:40 PM
pro382d's Avatar
that is true about the camaro seats but i modified mine and now they work just fine with the
