Drag Racing Tech
Is there a way to cool trans fluid with engine off?
Old 03-28-2010, 01:55 AM
brandonppr's Avatar
Default Is there a way to cool trans fluid with engine off?
Sometimes in hot laps I need to cool trans faster. Is there something I could use to cool it in the lanes with the engine off?
I have a small cooler with a fan on it, but it don't cut it sometimes.
I have EWP and can cool the coolant in seconds.
Old 03-28-2010, 09:37 AM
koolrayz's Avatar
Many run a small pump off of the oil pan circulating a fan/cooler combonation. I used an adjustable relay with a temp sensor in the oil pan. I also run it off a hotwire so it runs until the trans is down to the preset temp in between rounds.
Old 03-28-2010, 10:01 AM
brandonppr's Avatar
What kind of pump do I look for? I can use the cooler I have with the fan and get the pan tapped if I had a pump.
Old 03-28-2010, 10:58 AM
92slowmaro's Avatar
do a search on auxilary transmission pumps. alot of people use them when towing there vehicles behind a motorhomes
Old 03-28-2010, 11:39 AM
koolrayz's Avatar
I use the smallest of the three in this link, I think it was around $250 delivered with the extra fittings.
Weldon makes a really good pump but it costs a lot more. I used the hayden thermostatic relay, its adjustable down to 90* and has a bypass so you can run it nonstop if you like.
http://www.rbracing-rsr.com/oilsystems.htm
Old 03-29-2010, 09:27 PM
brandonppr's Avatar
Thanks for the help.
