Battery relocation help!!!
Im relocating the battery to the spare tire well. I have everything almost wired except the battery terminals. I have a 1/0 wire running batt to alt. I have a second 1/0 wire running from the batt to the starter then a 4ga going from starter to the factory fuse panel. My question is should I run a circuit breaker in the line from the alt to batt? If so what amp? 150? 200? The alt is the factory alt with no extra current draw... Thanks
