Drag Racing Tech
Kind of a dumb question...
Old 04-15-2010, 06:54 AM
Wicked94Z's Avatar
Default Kind of a dumb question...
Got my SOS cage kit, and I plan on driving to the shop for the install. Will the car run with the dash out of the car? I'm thinking it will, but just wanna make sure before I go stripping the whole interior out
Old 04-15-2010, 08:33 AM
z28rob18's Avatar
i think it will as long as the boxes on the passenger side are hooked up. i dont remember but i think i had mine running with the dash out
Old 04-15-2010, 09:06 AM
airfix's Avatar
Keep everything connected if you can. When I did my HVAC delete I took out my dash and hand pretty much everything disconnected then I realized I left the windows open and the car was outside. So I hooked up the battery thinnking it wouldnt be a problem to put the windows back up because I didn't disconnect the window switches and something behind the dash started smoking. The dash was still partially in the car at that point so I couldnt see what it was. Right away I stopped and once the dash was back in everything still worked fine. So I'd just plug everything back in once the dash is out just incase.
Old 04-15-2010, 09:18 AM
tektrans's Avatar
I have a '98 TA and same as you I planned on driving to the shop for the 10pt cage install, stripped everything out. Apparantly the alternator doesn't charge when the guages are disconnected. Car died about a 1/4 mile from the shop-how ironic.
Old 04-16-2010, 12:05 AM
Wicked94Z's Avatar
alright, so keep the cluster plugged in and I should be good... thanks guys
Old 04-16-2010, 03:36 PM
airfix's Avatar
keep all the little boxes and **** conected too just to be safe. Good luck, and make sure you post pics. I'm sure it will look awesome.
Old 04-16-2010, 03:38 PM
Duffster's Avatar
can't answer for the whole dash, but I've driven w/out the cluster in... 01 Z...
