Radial 4th gen suspension help!
4th gen drag radial 3350lb,315 m/t , bmr t/a, lca, koni double adj coilovers in rear, 5 compression, 6 rebound, 3.89 gear, Front is santhuff strut, singles, 632 12 deg. powerglide 1.80 1st, leaving around 3600 rpm.also tried 3400, We have tried bringing a small hit off the brake and have tried hitting the tires harder with a little bigger hit and neither has worked. It will start to hook and leave good but then just blow the tires off about 30-40 ft out. Any input would be greatly appreciated. Also we are using a edelbrock progessor.
Yes we race majority at dinwiddie. Madman, ill post videos when i get home,and also give you the other chassis info, i do know the pinion is at -1*, the lcas are -2*. and theres no ballast in the car.Thanks for the responses
ok, sorry about the delay on the videos. Here are some from last weekend and yesterday from MIR. Yesterday the track was hot so not the best conditions.
http://www.youtube.com/watch?v=lzEY5vvDvMQ
http://www.youtube.com/watch?v=8jBfJNwFOAw
