Drag Racing Tech
9inch housing ends
Old 05-25-2010, 02:43 PM
venom99's Avatar
Default 9inch housing ends
has any one put these on a ford 8.8 rear and if so how are you geting the axcles out of the rear for gear changes
Old 05-25-2010, 08:00 PM
venom99's Avatar
any one
Old 05-26-2010, 06:24 AM
LS1Tech Sponsor
MADMAN's Avatar
I use the 9" ends on all my 8.8 builds. You will need to get the 9" bearing when you order axles.
__________________
www.madmanandcoracing.com
225-343-9029
Old 05-26-2010, 07:46 AM
venom99's Avatar
are you geting the early or late style ends and also when taking axles out how are you doing that if they are pressed in
Old 05-26-2010, 11:37 AM
LS1Tech Sponsor
MADMAN's Avatar
The brake backing plate holds the axles in. Its not the early or late. I use Strange ends and the brakes will bolt to them.
__________________
225-343-9029
Old 07-02-2010, 01:30 PM
Gimme's Avatar
I'm not too familiar with the Strange ends, but you can also order the Moser 7900FM 9" ends. The 7900FM ends will let you bolt up your stock brakes and backing plates. Again, I'm sure the Strange ends are great, as well, but I've always used the Moser ends...which are top notch. Just get the set of ends that are less expensive...sounds like you can't go wrong with either brand. As mentioned above, make sure you order the correct bearings when you order the ends.
Quick Reply: 9inch housing ends
