guys I need some help on making a couple decisions...
welp this is the setup I have
402 iron block topped w/ Meaux Stage III LS6s
FMS 259/267 on a 113 + 3 solid roller and T&Ds
a ported Fast 90 w/ a NX 2 solenoid direct port
backed w/ a rossler 400 w/ brake, 2.75 first gear and an ATI treemaster 4000(setup for a 200 shot)
I'm gunna put a MW fab 9 w/ aluminum section and 3.90s w/ a 28 or 29" tire.
Well what I'm thinking about doing is going to a Super Victor intake and accufab TB w/ a dominator flange.
I know the camshaft isnt gunna be what I need.
So I was wondering if you guys think I should stick w/ the 90 or try to SV and see what it does?
or should I just go ahead and swap out the camshaft for one on a 109 or 110 LSA?
I also thought about buying the SV and going to the track and swapping intakes while I'm there and see what happens(I know the tune will need to be different but I can handle up on that)
IF I do this I'll go ahead and trim the cowl panel as needed before I get there of coarse.
