Drag Racing Tech
BMR Torque arm RELO crossmember which holes to run?
Old 09-06-2010, 12:46 PM
355z28's Avatar
LS1Tech 10 Year
Default BMR Torque arm RELO crossmember which holes to run?
Im installing a BMR torque arm relocation trans member. The front mount has several holes for adjustability. The car is stock ride heigth and Im unsure of wehre to run the front of it at.
Thanks
Austin
Old 09-07-2010, 08:36 AM
BMR Tech's Avatar
Looking at the mods you have in your sig I would run it as high as you can to begin with.
This is going to make the suspension react the quickest and put a quick snap on the tire to help it hook.
Old 09-07-2010, 08:53 AM
355z28's Avatar
LS1Tech 10 Year
Thanks, The car usually 60's around 1.61-1.68. The car dead hooks but then the back lifts up spins again then hooks. Im hoping this will fix that problem because I was running the stock arm.
The car should run 11.0-11.3.
Quick Reply: BMR Torque arm RELO crossmember which holes to run?
