Drag Racing Tech
Just picked up a set of QA1's where to start?
Old 10-15-2010, 11:35 AM
355z28's Avatar
Default Just picked up a set of QA1's where to start?
A friend gave me a great deal on some QA1 12 ways. Where the best place to start with adjustments on these? The cars 3600lbs and as of now hits the tires too hards and blows the run. Im going to lower the torque arm in the front mount and install these. Wheres a baseline?
Thanks
Austin
Old 10-15-2010, 11:53 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I assume you have rear 12 ways. No need to touch TQ arm to install.
IMO you should be able to use exsisting hardware. On my 12 bolt I had to get some Grade 8 washers to shim it out from the 12 bolt rear.
Settings depends on many factors, on my heavy M6 car we are expecting on a Bias Ply either 7 or 8 which is pretty hard. I drive around on #5 setting. No issues.
What tire do you race with??
Old 10-15-2010, 12:27 PM
Firehawk441's Avatar
2-3 front
8-9 rear
Old 10-15-2010, 10:35 PM
Duffster's Avatar
btw, if you're not at -2.5=-3.5 on the T/A already, thats a good spot too.
Old 10-16-2010, 08:25 AM
355z28's Avatar
I have the BMR adj cross member up front, I was at the top hole. I dropped 2 holes and reset the pinion angle at -2. I set the rear shocks at 8 and the fronts at 3.
Ill work with it today at the track, Thanks guys,
Old 10-16-2010, 08:33 AM
Duffster's Avatar
Good day for it. . . nice and cool here in Iowa
Old 10-16-2010, 09:33 PM
355z28's Avatar
New PB tonight, Im still spinning on the initial hit, but my 60ft was very consistant. 1.60-1.61 for all my passes.
Its transfers great then spins around 10ft. Im leaning torwards they're just old tires. I think they're 5-6 years old.
I ended up 2 on the front and 8 on the back at the moment.
Thanks for the help guys.
Old 10-17-2010, 12:33 AM
Duffster's Avatar
What were your times? Mention PB???
Old 10-17-2010, 09:14 AM
355z28's Avatar
11.46@119 with a 1.60 60ft. not to bad. If I get a new tire I think it will go faster.
Old 10-17-2010, 12:41 PM
Duffster's Avatar
caged already?
Old 10-17-2010, 01:49 PM
355z28's Avatar
No cage. Maybe this winter. Its tough to put one in when your on the border line like this, I put one in Ill slow down where I dont need one lol. Either way Ill need it when I spray.
