Rear lower control arms?
What are you guys doing to get back the right angle after lowering the car? Car hasnt been running in a while but finally got it back together and noticed this. Are you just making a new bracket for the rear end to drop it more?
lca angle, not pinion! Anybody know if the relocation brackets will fit over the moser rears with there reloc. brackets already installed? Had a 12 bolt before the 9 with reloc. brackets but when i bought the moser 9 they offered theres for free so I took it. Has four mounting holes but still isnt enough. I will just buy another set of reloc bracket to extend mine even further if it will slide over the existing moser piece enough to not be dragging the ground and to make a diff.
