Drag Racing Tech
Th400 with 4.11 gears?
Old 05-25-2011, 03:32 PM
General_Joser's Avatar
Default Th400 with 4.11 gears?
Building a Fox body with an ls1 i want to put in a Th400, im working on the rear end right now, im going with a 28" tire would the 4.11 gears work well? or should i get different gears, would i be able to drive it on the street?
Old 05-25-2011, 03:44 PM
subhumanzz's Avatar
my car runs around 3k@55 mph with stock gear set th400, 4.11's and 28" tires. i think top speed with the 4.11's and 28's is around 142 mph.
Old 05-25-2011, 05:05 PM
Minshall's Avatar
I got a TH400 WITH 4.11s and a 28inch tire. 55 mph is around 3300 rpm. Its also gonna depend on what converter you use too. Mines fairly loose.
Old 05-26-2011, 08:32 AM
SuperSlow02's Avatar
Same results here 4.11s/28
Old 05-26-2011, 09:11 AM
Internet Mechanic
BlackScreaminMachine's Avatar
All I can say for street use is to make sure you can monitor temps and run a good cooler. If I wanted a NO O/D trans, this would be the one and I would do exactly this.
Old 05-26-2011, 10:56 AM
sounds good guys 4.11 with 28" tire it is
Old 05-26-2011, 10:11 PM
JRracing's Avatar
I have a mustang with a th400 and 4.11 gears. It has a 325/50 drag radial on it right now. But It had a 28" tire on it the last two years and I drove it on the street around town a bunch.
I could roll 45-50 pretty easy but much more than than it was turning about 3500+ rpm's. I go on true street drive's in the lsx shootout and it does fine.
Old 08-28-2011, 09:44 AM
tboysen00's Avatar
What type of rpm's are you running at crusing about 65 with your 325/50? Thanks
Old 08-29-2011, 09:13 PM
ThreeHonks's Avatar
28s and a 4.11 is a good combo. I will spin about 2800-3000 rpm at 55 mph
Old 09-02-2011, 10:51 PM
nastychevelle's Avatar
i had a th350 with 4.11's and 28's and i loved it.
Old 09-03-2011, 12:51 AM
blk99sleekbeak's Avatar
x2 on this question. I have thought about doing a 4.10 but i also have a 50 sidewall (275/50's to be axact) and i still drive it alot on the street. I figured the 4.10 would be too much on the street with this tire and i plan on running the 275/50's for a while. Ill probly just stick with the stock 3.42's
Quick Reply: Th400 with 4.11 gears?
