which cam gets low 1/4 numbers
i am about to start building my ls1 for my 68 firebird, and i have been goin back ad forth on if i want the car to be stealthy or not, and i have finally come to the desicion that i want people to hear the power of the ls this motor will be a cam only car for the longest of time, so i was hoping that some of the guys around hear that i have seen and tried a few cams could give me some help. i dont want a terribly loud lope, this is gonna be a daily driver, so i want the power under the curve maybe a lil higher than stock. i do want it to lope a lil tho i will also be running a yank 3500 plus all the bolt on's and i want to beable to get the lowest times possible. so what cam will give me about what in the 1/4? thank you
daniel
daniel
Humanitarian
I have a buddy that runs a 224 cam with long tubes, y-pipe without cats, a Loud Mouth and two little bullets and it sounds nice. With a nice tune there is just about zero cam lope and it's really well mannered.
BTW, with LS1 ported heads he made something like 410rwhp 405rwtq
i looked at the g5x3, but it makes alot of high rom power, and i am lookin for under the curve, and that thing is just nasty lol. i'm kind leanin toward a futral cam but i dont know which one. what would be a good choice? thanks
daniel
daniel
If low ET's is your goal, you gotta consider suspension to put that power to the ground. Just a cam won't do it. From front to back, it all works together. But i'm sure you knew that already.
WG
WG
hey i have it all thought out. my front fenders and wheel wells are gonna be fiberglass. i am getting a set of caltracs for the rear leaf springs along with a set of 50/50's. the front will most likely be a 60/40, but i was kinda considering the 70/30's. and then there is this company that makes a set of "lift bars" that replace the oem ones and they are designed to relocate the suspension center point of the car. and with all that backed up by either a pair of et streets or slicks and i should be aight lol. but yea any more thoughts on a cam?
daniel
daniel
