Could you drag guys help me out....
i posted this in the programming diagnostic section, but it mainly is meant for drag racers...
https://ls1tech.com/forums/pcm-diagnostics-tuning/156990-brake-abs-inop-lights.html
In reference to running a 28" tire in rear with the skinnies up front, and the ABS INOP / BRAKE lights on the dash coming on and if there is a way to get rid of it. Any help is appreciated.
Chris
Chris
https://ls1tech.com/forums/showthread.php?t=156990
Chris
Chris
Mine went away after a while. The first time I drove it with the slicks, it threw the ABS Inop. But after that, never a problem again. Until I put the spool in. Then, I pulled the gauge cluster and put some electrical tape over the bulb. No more ABS Inop light. At all.
