Drag Racing Tech
What gauges are you running?
Old 08-11-2012, 07:34 PM
01_ram-air's Avatar
Default What gauges are you running?
I have to buy a Trans Temp gauge but will eventually get two more gauges for my 3 gauge pod. I'm curious what gauges you are using and what brand/series. For example, if you're using Autometer... is it the phantom II series, Elite, Prestige, etc. What issues have you had... not working correctly, color doesn't work all the time, wish you went with the electronic sending unit, etc. Any advice or experience will be helpful.
Old 08-11-2012, 08:17 PM
GMRACER13's Avatar
Fuel Pressure and Nitrous Pressure. Do I have to do everything for you?
Old 08-11-2012, 08:41 PM
djfury05's Avatar
Dual Aeroforce with a wideband. Would of had fuel pressure as well but the fitting didn't have an o-ring provision for my fuel rails so fuel sprayed everywhere.
Old 08-11-2012, 10:31 PM
01wss6's Avatar
I have a full sweep electric trans temp gauge for sale on ebay
http://www.ebay.com/itm/170892418809...84.m1555.l2649
Old 08-12-2012, 09:49 AM
Heyfred's Avatar
Speed Hut
http://www.speedhut.com/
Old 08-12-2012, 10:21 AM
+badss+'s Avatar
here's what mine look like i also have my trans temp gauge down by the ashtray
Old 08-12-2012, 11:29 AM
fex77k's Avatar
Pro comp Auto Meter, large tach, oil pressure, and coolant temp.
Old 08-12-2012, 03:45 PM
studderin's Avatar
shift light
thats it
Old 08-12-2012, 06:11 PM
TurboStangJON's Avatar
^Same here, logged everything else with a laptop.
Old 08-13-2012, 12:52 PM
01_ram-air's Avatar
Thanks guys... decided on going with the Auto Meter Ultra lite Digital series. Wideband, Fuel pressure, and trans temp. $654 total.
Old 08-13-2012, 02:22 PM
fex77k's Avatar
I also run a standalone pyrometer and LM2.
Old 08-13-2012, 05:31 PM
DietCoke's Avatar
Prosport evo gauges. NOTHING can touch them for the price.
Old 08-16-2012, 05:51 PM
RENE'S RAGE's Avatar
Is that the ES Series?
Old 08-16-2012, 10:02 PM
+badss+'s Avatar
yes mine are autometer es series
Old 08-17-2012, 07:01 AM
c0ncEpT's Avatar
Phantom II
Trans Temp, Fuel pressure, and Boost.
Old 08-17-2012, 04:19 PM
Thank you Sir!
I'm leaning toward the ES Series also. Because it lights up in red.
Trans Temp and Water Temp. Maybe Oil Pressure.
Where does the Oil Pressure Sensor go?
Do you take out the stock sensor or what?
Old 08-17-2012, 04:42 PM
subhumanzz's Avatar
Old 08-17-2012, 04:46 PM
+badss+'s Avatar
Originally Posted by RENE'S RAGE
Thank you Sir!
Not sure. If it's electric it should go in stock location, manual may be different.
I love the look of the es series because the red matches theme of my car,
I'm using the boost,wideband,fuel pressure,trans temp gauges.
Old 08-17-2012, 05:03 PM
Yeah, I'm going with the ES, because my dash lights up in red also.
Old 08-17-2012, 05:21 PM
DietCoke's Avatar
Thank you Sir!
PRosport evos light up red or blue (user selectable) and come with senders for $55-85. Much cheaper then aeromotive, digital, and super nice.
http://prosportgauges.com/evo-series-red-and-blue.aspx
Quick Reply: What gauges are you running?
