Inserts for stock camaro seats and a 5pt harness
I heard a while ago that someone put inserts in their stock camaro seats for a 5 pt harness. I never have seen pics tho. Anyone have pics of this? Im assuming i could just buy the inserts and any upholstery shop would be able to do this.
I did it to a set of Camaro seats I not longer have. So I don't have any pictures but you can buy the inserts at Hawks 3 gen. They have a picture on there web site. I pulled the cover off first and traced it and then cut out on the foam first. Then reinstalled the cover and carefully cut the cover a little at a time until you can push the insert through. Also when you removed the cover take your time and be careful not to pull the Velcro off the foam.
Ask and you shall receive. http://www.hawksthirdgenparts.com/gu...yle-seatbelts/
