Car isn't planting mostly spinning...
Race your car!
Thought I read earlier that you were spraying car, my bad I have a couple different threads of similar questions/issues I am replying to.
If you're planning on spraying it I wouldn't do anything until you see what it does with that added into the picture as you're going to be starting all over again.
As suggested for now up the air pressure, may want to up it until you see some spin in the first 20 feet then back it off a lb. I'd tighten the front end up a setting or 2 as I think it raises too quickly and settles too quick.
When you go to spray it hit it right out of the gate off the transbrake. No delay nothing, start there and see if the car and your typical track prep will take it. Tighten front end a couple additional settings for first hit and put tires back to 13 for first hit.
The 500hp was on an engine dyno? What's the weight of the car? I think the 60ft and et is from power and converter with a heavy NA car. When you start spraying that converter will be a good bit loosser and 60ft times will be cut. I don't know your cam specs, but guessing off of horsepower and being all motor I think your car with a 4200-4500 stall would drop a tenth on 60ft. I think you need to hurry up and spray that thing to see what you have and work from there.
From what I saw in the video it looked like the car starts to transfer then the front stops lifting and settles back down quickly and you see the weight shift back to the front. What shocks are on the front? If they are adjustable, where are they set? looks like you have too stiff of rebound on them
LS1Tech Premium Sponsor
You can try to tighten up the front shock extension to help promote the car moving forward instead of up, and aid in wheel speed at the same time. If you have LCA relocation brackets on the rearend maybe move the LCA up one hole toward the rearend.
You have a lot of variables and depending on what you are doing will change what setup will work the best. Foot brake, transbrake, nitrous or not... all of this will affect what the car needs.
All Strange shock valves are the same... clockwise to stiffen, counterclockwise to loosen. The single adjustable shocks are only adjustable on the extension, the compression is set.
Race your car!
I would tighten the front end up a good bit, start there. I don't like using travel limiters I prefer the shock to control the up travel rate, and it usually results in a more harsh unload when the tires touch back down. I know it prevents wheelies, I have used them to stop just that and it works, but the shocks if the extension is slow enough will effectively do the same.
Car finally had a 1.59 60ft on motor I knew it had one in it on motor car ran best of 7.22 last weekend when normally running way slower. Again this is on a very tight converter off footbrake. Only able to launch at about 2 grand on footbrake. Can't wait to spray the car and see what kinda 60 fts I get then! Think I'm about done for this season though need to finish up the car this winter. Lots of mods in store hopefully! Thanks for all the suspension tips and tire pressure recommendations
#32
Anything in the 1.5 range is promising, you're knocking on that door! Keep up with testing, make sure you start keeping run logs with all your setup info, even weather conditions and track temps. it's tough to gauge where the car really is at with the converter setup right now, but once you start to lay more power to it some things will need to be adjusted. Hit us up, be glad to help.
#33
#34
Race your car!
First grand take hit take a lb of air out of the tires. It's going to hit them a lot harder and this may assist in planting them and prevent excessive wheel speed. Other than that put it on the brake, foot to the floor and let it eat.
If you do get your nitrous hooked up take the lb out of the tires, tighten the front extension 2 more for the first hit and try to just leave on all of it, or delay the hit a tenth of a second to start, or leave on 75% and all in at .2 as you should not need much more power management than that.
