Harlan - Anyone - Help with the NOS - 2-step hook up
I posted on the other 2-step trend, but I really need some help quick.
I have tried to hook the relay up:
2-step yellow wire to 86
Positive from activation switch to 85
30 to a ground
87A to the WOT switch - middle connector
Also, exactly how would I hook up the MSD window switch with the 2-step.
Any help would be appreciated.
David
<small>[ June 19, 2002, 08:34 PM: Message edited by: Navy David SS ]</small>
30 to a ground
David
Re: Harlan - Anyone - Help with the NOS - 2-step hook up
David
The best bet is to have the relay interupt the power supplied by the arming switch for you nitrous.
2 step yellow to 86
constant 12V or 12V from your arming switch to 85
depending on how you have your system wired...
http://www.wam.umd.edu/~krzew/n2.jpg
going from that, you would place the relay inbetween the arm switch and the WOT switch. 87a and 30.
unless the 2 step is armed, 87a and 30 are connected.
2 step yellow to 86
