What psi for even wear on 275/40 Nittos??
Re: What psi for even wear on 275/40 Nittos??
Ive had 8 or so sets over the years. I find 22psi for daily driving, and 18 at the track. I usually get 10-13k from a set. Im on the highway a lot. But, Im at the track weekly and do a pretty good burn out before each pass.Any higher, and they wear the center out too fast. Hope this helps!
!Dial-up Director
I'm also running 22psi on my current set of 275/40/17 Nitto DRs. I have ~15k miles on them, and if it weren't for a bad (or lack of ) alingment they would go another 5k ( one is worn bad real fast after I lowered the car, other still has plenty tread ). If you run the nittos any higher the middle will wear faster.
Justin
Justin
