Drag Racing Tech
ET Streets/Suspension
Old 11-18-2002, 03:12 PM
MYBLKSS's Avatar
Default ET Streets/Suspension
What suspension parts should I upgrade when I switch over from nitto's to ET Streets.
The cars Suspension right now is 100% stock and I do Not have t-tops. It is a cam only A4 making 350hp & 388Tq at the wheels.l I am going to get a drive shaft loop but not sure if anything else is needed or if any other suspension part will help shave a little more et.
Old 11-18-2002, 03:59 PM
MYBLKSS's Avatar
Default Re: ET Streets/Suspension
TTT
Old 11-18-2002, 06:53 PM
SILVER BULLET's Avatar
I benefited alot from an adjustable torque arm and HAL shocks
My torque arm is a Random Tech, no problems after 2 years, but I'm sure their is a better unit.
The HALs are twelve way adjustable for the best tuning and better weight transfer.
Old 11-18-2002, 07:12 PM
GeorgeC's Avatar
I'd hold off until you make some passes down the track, and see how well your current suspension set up works, then start thinking about making changes. There have been quite a few really quick cars still utilizing 100% stock untouched suspension.
Most folks will start with LCA relocation brackets and/or adjustable shocks. An airbag in the RR coil spring can work wonders as well.
Old 11-19-2002, 04:36 PM
MYBLKSS's Avatar
Thanks for the help. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> any other suggestions
