Drag Racing Tech
Where can I get the light weight battery terminal adapters?
Old 11-20-2002, 08:57 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
Default Where can I get the light weight battery terminal adapters?
Anyone got a brand part# or location. I was thinking they were available from the local parts house , but no luck so far. I'd appreciate any info you might be able to offer. I know a lot of you guys are running these batteries.(Hawker & Dynabatt). TIA.
James
Old 11-20-2002, 09:18 PM
Iv_z28's Avatar
Default Re: Where can I get the light weight battery terminal adapters?
No need for new terminals... just used couple washers, and bolts supplied with the battery worked fine for me with factory terminals..
Old 11-20-2002, 10:57 PM
TXCAMSS's Avatar
I didn't get any bolts.I was under the impression that there was an adapter that could be screwed into the battery and still be able to use the existing battery terminal connections. I guess I could just get some bolts and use washers to connect it. I was looking for an adapter for a solid easy fix. Thanks.
James
Old 11-21-2002, 02:35 AM
JimmyKash's Avatar
thunder racing has them
www.thunderracing.com
check under ignition products
