Drag Racing Tech
Will I run out of RPM's
Old 02-21-2003, 05:23 PM
Chopstix's Avatar
Default Will I run out of RPM's
I have a 94 Formula M6
Current setup
bolt-ons/GTP stage 2 H/C & Nitrous
26x11.5-16 ET Streets
4.10 Gear
12.1@120MPH 2.0 60' (I know that sucks)
Am considering swapping for a 700R4 and leave the 4.10 gear I have been running.
My question is will I run out of gear with that trans /gear combo
<small>[ February 21, 2003, 05:24 PM: Message edited by: Chopstix ]</small>
Old 02-21-2003, 05:37 PM
McRat's Avatar
Default Re: Will I run out of RPM's
At 6500rpm running 26" tires, you will go 123mph.
At 6500rpm running 28" tires, you will go 132mph.
How high can you spin?
Old 02-21-2003, 05:50 PM
Chopstix's Avatar
rev limiter is set at 7000
normally shift at 6200-6500 depending on how the car is acting.
I just don't want the car wanting to shift into OD before the traps.
<small>[ February 21, 2003, 06:14 PM: Message edited by: Chopstix ]</small>
Old 02-21-2003, 07:31 PM
Bad Habit Bird's Avatar
Make sure it is a manual valve body setup and you should be fine. 3rd gear in the 700r4 is the same as 4th gear in you M6 <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Honestly I think you should spend your money on a 12 bolt instead of that 700r4, then you can actually launch that car HARD <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old 02-22-2003, 01:13 PM
Chopstix's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Bad Habit Bird:
<strong> I think you should spend your money on a 12 bolt instead of that 700r4, then you can actually launch that car HARD <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It is a swap situation, no money involved on my part <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
