LT1 rear brake assembly on a LS1 car.
Is there any way i can do this. Will all of the caliper brackes and calipers and rotors fit up to the ls1 rear end? Im trying to fit some Draglites with out no grinding at all and no spacers either.I can go to a Junkyard and get the stuff to do this with. And also will the LT1 setup work with welds, doing no grinding and spacers?
Re: LT1 rear brake assembly on a LS1 car.
you have to grind quite a bit on the LT1 rear calipers to get Pro stars/draglites on. the newer the pads, the more you will have to grind.
if you want no grinding or spacers, get a set of drag brakes
