need help for drag set up
i just got a slp torque arm adj.i got a adj.panhard bar and drag springs with one air bag in the right side.just woundering what pressure to put in the bag for drag racing.i also want to know what kind of angle i should set the adj. panhard bar and the slp adj. torgue arm too for drag racing.
thanks
jeff
thanks
jeff
Air bag - I ran mine at 15-17lbs. OR just buy an aftermarket rear sway-bar and get rid of the air bag. I run the Wolfe, but there are others.
Adj panhard rod (PHR) is use to center the rear-end - no angle. Adjust the PHR to center the rear-end.
Adj T/A -- believe most people use -2 degrees
David
David
