Drag Racing Tech
drag race battery and elecetric fan switch???
Old 04-07-2005, 09:12 AM
30th t/a's Avatar
Default drag race battery and elecetric fan switch???
those who have a lightweight battery and a electric fan switch, is it possible to run the electric fan while your in between runs at the track? or will the battery drain itself?
Old 04-07-2005, 10:28 AM
bad2000ss's Avatar
It will probably kill that little battery pretty quick. I haven't run mine down yet, but I am always careful not to leave the radio on or the ignition at ACC so the electric water pump doesn't keep running.
It may be a good idea to buy one of those portable battery chargers and take it to the track with you if you do plan on running the electric fans while the car is off.
Old 04-08-2005, 06:29 AM
BTL FED's Avatar
Thats why I run a full sized battery, one less thing to worry about, put the battery in the back where the weight helps, and take weight off somewhere else is the way I did it
Old 04-08-2005, 10:59 AM
rockcamaro97's Avatar
well, on that note BTL FED, what fullsize are you running? Ive been planning on runnin a full size batt and wondered what the weights were like on them.
Matt
Old 04-08-2005, 02:48 PM
BTL FED's Avatar
A turbostart 16 volt sealed battery ( I run a 16 volt system on my camaro)
Old 04-08-2005, 07:25 PM
theblur98ss's Avatar
I had a small battery and in cooler weather it woudln't even turn my motor over. One time I even had to get jumped by a mustang!!! I've opted to put an optima in the back. Just need to get time for the project now.
Old 04-09-2005, 01:12 AM
PRAY HRD's Avatar
i would suggest going with something in the 800+ cca range. i just bought an Oddysey 925. light weight, but not the lightest, but i should not see any problems with it even with the fans running in between rounds.
