Do V6 Springs in the rear change ride height/quality??
Im thinking about putting some in on my car for drag racing purposes and was wondering how much it changed the ride of the car. If it makes it ALOT different then I wont do it but if its not really noticeable then I will. It will be a long long time before I could ever go to a straight up drag setup so I thought this might be a happy medium.
I ruin the end of films...
You don't want softer springs in the back. The spring rate on the back of the 4th gen cars are adequate for drag racing. If you do anything to the back suspension, put a QA1 shock on w/ the stock spring. Personally, I'd do the fronts first.
FWIW, a softer spring in the back probably would lower the back end a bit.
Originally Posted by necrocannibal
Oh I could have sworn that softer springs in the rear would help "plant" the rear more as it would drop more when you launched.
