Drag Racing Tech
harlen 2 step install
Old 04-19-2005, 04:57 AM
chevytat2's Avatar
Default harlen 2 step install
does anybody know how to wire a harlen 2 step with a transbrake on a th400 in a 2002 z28 thanks Dan
Old 04-19-2005, 11:54 AM
bad2000ss's Avatar
I believe you are supposed to permanently ground the white wire and run the grey wire to your transbreak. The Yellow Wire is only used if you plan on running nitrous or some other accessory that must be disabled while the 2-Step is active.
Hopefully Harlen can step in here and confirm this. I know there were a couple old topics on the subjects, my my earlier searches yielded nothing.
I believe this is what it should look like for an Auto Trans with Transbreak. This diagram is with a nitrous application....
Old 04-19-2005, 01:25 PM
mike@xtreme's Avatar
I believe that the yellow wire completes a ground when the two step is active.
You can also hook the yellow wire up to the ground side of a 12V LED and the other side of the LED up to a all time 12V source. This provides a light on when the two step is active. I did this so I can make sure that it is active when I floor it (I use the footbrake, so it is much more critical for me).
Mike
Old 04-19-2005, 02:11 PM
The Juggernaut's Avatar
I can tell how to do it without a relay if you want, it's easy.
Tie the white and gray lines together into one wire, then run that into two wires.
(One to the trans button, one to the Tbrake solenoid.)
Ground the other side of the button and run a hot 12 volt to the other side of the solenoid.
See, simple.
Old 04-19-2005, 07:50 PM
Loudmouth LS1's Avatar
I run a double pull relay (think that's what it is, can't remember exactly what it's called now for some reason) to pull the ground from my nitrous kit when the t-brake button is depressed and then it gives it to something else, well right now, I have nothing in the spot that it switches too, but when I hook up the 2-step, i'm gonna run the ground for it over to there, so when the t-brake is on, it goes on and the nitrous goes off!
