Launching Help!!!!!!!!!!!
Ok tonight is the first night out with a two step!!
M6 (WITH ALUMINUM FLYWHEEL)
4.11 gear
rite at 400 RWHP
stock suspension
16X10.5 et streets
3608lbs with me in it.
I use to rev and dump at like 6000 and it jerks the wheels up and then falls a little on its face. so what should I set the twp step on???
4.11 gear
rite at 400 RWHP
stock suspension
16X10.5 et streets
I would try 200 RPM higher, If you don't want to go higher try adding a little air in the tires (about 1lbs)
What was your sixty?
I am launching a 5800 on poor tracks and not getting a good hook.
