Installed 12 bolt, now traction problems
I installed a strange 12 bolt in my TA about a month ago. Now the car will not hook up. I went from a 10 bolt 3.73's to a 12 bolt 3.73's. My car has all the bolt ons and a 224 cam, pt4000 stall, I running ET streets. My 60 foot used to be 1.59 to 1.62, now I'm in the 1.70's. Could my pinion angle been affected with 12 bolt? I also installed BMR LCA's when I installed the 12 bolt. any ideals what could be causing my problems?
LS1Tech Sponsor
Check and reset your pinion angle. Did you change ride height when the new rear was installed???
I didn't measure the ride height before and after but it looks to be about the same. I still have the factory torque arm so I guess it's time to get an adjustable one.
