Launch RPM'S AND ET predictions
Manual trans guys , what rpm's are you leaving at? I will be running the new BFG g/force drag radial.
I will not run with the NOS as it is not fully wired.On motor I made 502 rwhp and 454 ft lbs. Can anyone with a similar combo tell me what you run in the 1/4, 60' and mph.
depends on your weight, what supporting suspension mods you have and a few other variables. I could see you pulling high 11's though if you're on street tires at around a 4000 lb raceweight pulling 2.0 short times(which im guessing, i have no idea of the weight of your car).
Nate
Nate
