Rear QA1 shocks clearance issue
While installing the Spohn pro-series rear drag sway bar and some rear Hal-QA1 adjustable shocks today. We noticed a clearance issue between the shock and the Spohn sway bay. The adjustment **** on the shocks doesn’t have enough clearance and will hit the sway bar. Ended up rotating the shocks so that the adjustment **** is facing the LCA's and gained a some extra clearance. Anyone know if this will work or are there any other solutions for this problem.
Just wanted to see if other had any problems with them hitting or breaking off the ****. We're going to leave the shocks with the **** turned out facing the LCA's. Hopefully we want run into any other problems.
