Launching of the REV LIMITER w/ strange 12 bolt. is it possible?
strange 12 bolt, BMR T/A, Chrome moly driveshaft, Rodends LCA and PHR 28x11.5 e/t streets spec stage 3 clutch.....with this set up is it possible to launch @ the REV LIMITER?
anything is possible, now whether or not you tear up something else is the question. Posi in the rear (seen them go in the Strange's), blowing the clutch out, popping the input shaft in half, etc.......
We launch my 97 off the 64-6500 limiter, stock clutch, stock valve springs, Moser 12 with 4.11s, ET Streets 26x11.5x15. Stock sway bar, stock shortened DS (steel), Herron Performance Adj LCAs and PHR, Spohn Adj TA set at -1.5*.
Still have the relocation brackets to add and have not luckily nailed a perfect launch, we have spun each pass (12.5psi), this is good b/c of the clutch, I am on borrowed time with it...
