Drag Racing Tech
Bump stops, Who has them?
Old 07-28-2005, 01:00 PM
waltsfastz's Avatar
Default Bump stops, Who has them?
I am running 275/60/15 MT DRs with 10 inch prostars. When I let the rear all the way down on the stands the rear tire hits whats left of the bumo stop mount(Has been trimmed) When I take the springs out to inspect the travel of the rear on of the torqu arm mount bolts( The ones that holds the mount to the housing threads on a nine inch) hits the bottom of the car. Im tring to figure out why in the hell I cant cut better than a 1.75 60 ft with Adjustable ta, Lcas, panhard rod, No sway bar, air bag and a 4:30 gear with 28 inch tall tires.
Old 07-28-2005, 01:45 PM
FIREHAWK #07's Avatar
you can get the stock ones from the dealer for like 25 each .... i have also seen that Energy makes some Poly. ones BUT not made for our vehicles in particular....
Old 07-28-2005, 06:40 PM
waltsfastz's Avatar
Im asking rather I should go ahead and cut the mount the rest of the way off or try to make some bump stops functional
Old 07-29-2005, 06:21 PM
Retired Street Racer
Matt D's Avatar
i removed mine completely. i have LCA, PHR, and SFC, and with stock internals, i cut 1.59 60fts.
Old 07-29-2005, 08:50 PM
kp
kp's Avatar
I trimmed about 1/2 of mine off, I leave them on there because I think it would put the 9" torque arm mount through the floor if I hit a big enough bump. If I wasnt driving the car on the street I would just cut them out though. Mine just hits the tire when I let it all the way down so I usually just loosen the wheel if I need to let the rear 'hang.'
Old 07-30-2005, 06:58 AM
waltsfastz's Avatar
Thanks, I already have it off but I was wondering about finishing the mount off, Thanks again
