Drag Racing Tech
Drag Sway Bar Question
Old 01-04-2006, 09:57 PM
CanuckSS's Avatar
Default Drag Sway Bar Question
In the picture below, does the triangular bar pivot at the area that is circled or is it welded solid?
Is their a bushing in that area?
Sorry if this is a stupid question, I searched without any results.
Thanks in advance,
Dave
Old 01-04-2006, 10:49 PM
Z8'S's Avatar
It should pivot.If you disconnect the links on both sides pass/driver the arm should rotate freely. With Driver seated in car I connect the driverside arm and then get the bolt to freely pass thru on the pass side .Then add preload of 1/8 th turn
Old 01-05-2006, 02:35 PM
CanuckSS's Avatar
Thanks for the reply.
I guess I just don't understand the concept/physics behind a sway bar.
So, does the bar work like a torsion bar?
Old 01-05-2006, 04:52 PM
Z8'S's Avatar
It is actually a anti-roll bar.It works to keep the body twist stable and the car launching level right to left.
